Hello, I haven’t been able to solve the problem for a month now, last year I bought myself a laptop based on 8845HS 780M. The point is that at any random moment in the driving situation the game may freeze.
What I did, window mode and wrote to support and everything else What I did not do, window mode and wrote to support service and everything else, turned off various functions to reinstall the driver, nothing helps. T When this happens, this window pops out. AMD software detected that the driver response time was exceeded. A problem report has been created that can be submitted to AMD. There is a sound of the game, but everything is frozen.
Is there a Hardware-accelerated GPU scheduling option in the settings for your 780M? That was a workaround for the Ryzen AI Max+ 39x systems. It’s a different integrated GPU so possibly irrelevant but if you see that setting I would try disabling it.
Otherwise I think you probably need to contact support.
That does not make any sense to me. I can’t think of a reason why standing on the trainer would affect game stability. Ask support to look at your logs.
Unfortunately, I cannot find a pattern, I can only say one thing, perhaps, but this is not a fact, there is one nuance that I have only guessed about now. There is an application AMD adrenaline. In this application, games are automatically found when you launch them, I think hmm.. the game was not found, I will add the zwift myself. And now I deleted it and tested it, I’ll tell you the result later. Although all settings for the game were disabled, as the support said, it may still affect something.
I have no idea if it could help but the other thing you can control is the amount of RAM set aside for the GPU. On some systems this is managed in Adrenaline, and on others it’s done in the system BIOS.
