update failed during patching.Error Code:Z117 at line 598
I am a chinese user.
Z117 usually means there was a network problem and the patch was corrupted. But we also have seen some issues (maybe unrelated) with Chinese localization and sogou pinyin input in the past. I would try resetting the router, or using a different network first. You may also need to reinstall. If that fails I would try Microsoft input or switch to English for the update and see if that helps. If you get stuck contact support.
thanks Paul,I can’t update zwift at my PC ,my rider firend tell me the problem is network problem,we are all use china mobile network,he advice I use cellphone’s hot spot,I will try.i can use my iphone’s zwift sofeware.
