I have a problem with last update.
At the end of update generate error
Update failed during patchin. Error Code z117 at line 598 in c:\Git\game-client-clean\Projects\ZwiftApp\CODE\Patcher\Patcher\Patcher.cpp
Before this update Zwift was work perfectly.
Operating system is windows 10. PC is I5-6500 Nvidia GTX1650 and 32GB Ram
I had try to reinstall Zwift without any result
Any suggestion?
Roberto
thanks for reply but…
In my account not have special characters
I’m admin of my machine
Any programs not interfering with zwift… in the machine I have only Zwift software
In the hard drive are much more than 4GB of free space
last but not least, before this update (may 2023 ) Zwift was work perfectly
I have try to instal Zwift in another machine but I have same error
Please help
Roberto
I’m surprised that support article doesn’t mention that this error is sometimes related to network problems. I would try rebooting the router, and if you have a VPN try enabling it before doing the update. You could also try using a different network such as a phone hotspot or if you’re using a laptop, take it to a cafe or library to try it on their network.
I thought this was normally related to an issue using mobile data as opposed to a normal internet connection.
Many thanks for suggestion…
in fact it is a network problem … since last week there are problems in my area due to bad weather
I changed carriers and the problem was solved
many thanks
Roberto
I think some cellular data carriers are problematic (Vodaphone?) but we’ve seen this with wonky routers and blocked ports from corporate network security, etc.
Yep, it’s always been voda whenever I’ve checked.
yes the operator carrier that gave the problems was vodafone
