The automatic updates always give me a z117 error. Possible because a special character (space) in the username or a synchronisation program. Disabling synchronisation does not help. Changing the username is not possible because of some expensive commercial software checks for the username.
Zwift is the only program I know which has problems with special characters (spaces) in the username, so I classify this as a (known) bug.
As a workaround I have to reinstall Zwift every now and than, but the download often gives the same error after first use.
Another workaround could be creating a new account only used for running Zwift
Hi @Wil_Sistermans_60, welcome to Forums. I’m Juan from Zwift.
Thanks @Paul_Southworth for your suggestions. The z117 error suggests that Zwift is encountering problems when trying to write data in the Documents folder on your computer.
Special characters in your administrator account username can cause encoding issues, making installation difficult. If you need help creating another account, please check this Microsoft support article.
You can refer to this support article for more info about Error Code: Z117.
Please write to us at support@zwift.com if there is anything else I can help you with. Thanks!
