Hello Zwifters,
We wanted to make you aware of upcoming changes for older operating systems running the Zwift Companion app.
Starting on May 31st, 2023 we will be deprecating Zwift Companion App for iOS 12.
Affected Zwifters currently using this operating system will see messaging within the Zwift Companion app, if applicable, and should also receive notification via email.
The Zwift Companion app will no longer function on deprecated operating systems.
Many existing devices running older operating systems can upgrade their OS without needing to replace the device.
Upgrading your OS will ensure your device is capable of the best Zwift Companion experience.
If your existing device is unable to upgrade the OS, Zwift supports a variety of devices and operating systems. It’s likely another device you already own will be able to run Zwift Companion as well. More information on supported devices can be found here.
