Unusual WKG DQ
Does anyone know why I would have got a DQ for this? It was a racing score event so entered the race I was eligible for and even if it was standard categorisation, I’m barely over the limit (not to mention the other riders power!)
The event wasn’t configured properly on ZwiftPower. The organizer can fix that.
Thanks Paul. Do you know what wasn’t configured properly?
WKG enforcement doesn’t belong in a racing score event. There’s no W/kg that is out of bounds in those events. This used to be a default setting in ZwiftPower so it was easy to leave it enabled accidentally. This started showing up a lot when racing score was introduced so they made a change so that new events would have it turned off unless manually enabled.
