For distance based upgrades I can go faster and select flat routes and influence how long it takes to reach the next level.
For climbing based upgrades I can go faster and select hilly routes or mountains to influence the time it takes to reach the next level.
There’s an incentive to put in more effort and I feel in control.
Not so much for time based upgrades. The incentive for me is “go slow with the least effort so I can go for longer.”
I don’t feel the same level of control regarding the leveling for TT frames compared to other frames.
I believe that it might be worthwhile to look for alternative processes to level up TT frames.
For example, the “power unit” of the “factory tour” challenge comes to mind. If the next level isn’t “10 hours” away but rather e.g. “20 Wh/kg”, I would be able to influence how long the upgrade takes and would have an incentive to put in more effort.
The power units of the factory challenge and its rate-capping are well-established.
Earning is rate-capped at a maximum of 4 Power Units per hour for a maximum of 15 Power Units per activity.
I hope that this request is not a duplicate and would like to hear your thoughts. Thanks!
I think you’ll get a lot of different thoughts based on what kind of riding people prefer.
Personally I’d have more of them elevation based, but we know that won’t go down well, or everyone will just use bots to do the upgrades (they do that anyway with all upgrade types) or will make themselves 50kg (the lowest they think they can get away with).
I don’t particularly like the TT bike upgrade process, but that’s the way it is set and trying to change it would cause mayhem with people in the middle of upgrading TT bikes.
I used a faster/lighter bike uphill on the biggest mountain in Watopia and switched to the TT bike for the downhill. It took a while but got the upgrades done without interrupting the riding I wanted to do.
I’m not keen on the whole upgrades concept at all, because it further disadvantages rookie Zwift users in most races/TTs, on top of long term users having fancy frames and wheels.
Upgrade unlocks via distance and elevation disadvantages weaker riders. IIRC so does “power units.”
That’s just false; the entire purpose of power units is to neutralize the system of upgrades.
It’s more difficult to be cheated as well because it’s adaptive.
It’s not advantaged by lighter riders, heavier riders, nor people that ride with bots all the time.
It’s honestly one of the best features solutions Zwift has come up with for a problem that I think we’ve seen.
The only real argument back would be that this is an advantage to people that don’t ride on zwift very often and likely don’t race which is already a stretch, and also makes up for the deterrent of it being disadvantageous to newer riders… because if they don’t race, they aren’t “the problem”. But that’s already fixed by locking out a lot of these bikes to level 40+ which is done anyways.
Regardless, it’s a system that promotes elevated efforts; not the persons that ride 20+ hours a week with a bot going 24+ mph at 120w and not the person that set their weight to 40kg and forgot about it (which yes, is absolutely very much still a thing; had a guy on my ride a week ago that seemed abnormally fast and kept going off the front of a B pace group doing very little watts).
The Zwift racing fiends are mostly not the people who got through the Factory Tour quickly in a legit fashion. Most races are too short to accumulate a lot of power units, despite the higher level of effort. I know people who are racing 4-5 times a week and their training volume is universally too low for making rapid progress on the challenge. It’s going to take them ages to get through it. I assume they are more interested in fun than training or challenges, and I’m OK with that.
that’s not how it works, doesn’t matter what your zFTP is, only weight and watts.
One power unit is one watt-hour per kilogram, or Wh/kg. If you hold 1 w/kg (say, you’re an 80kg rider holding 80 watts) for an hour, that’s 1 Wh/kg, or 1 power unit. If you average 2 w/kg across your Zwift rides, each hour of riding will earn you 2 power units.
It disadvantages riders with low power (whether or not those users have permanently low power because of age, health conditions, or just not being blessed with decent physiology).
Zwift already disadvantages such users when it comes to XP and Drops, and upgrading distance-based and elevation-based bikes.
So please let’s not take away the refreshing time-based TT bike upgrade level playing field from such users.
Perhaps I was confusing it with the functionality of the socks then.
Been over a year since I’ve finished the challenge and don’t think about this stuff very much.
That said; upgrades LIKE power units that are based on zFTP isn’t a bad idea.
I personally don’t mind that TT’s take time, it’s something different. If I hate anything I hate MTBs for being climbing based; not that Zwift knows what to do with MTBs anyways.
My main point is that I’d love to have the process of leveling up TT frames feel less passive.
I read concerns that introducing means to speed up leveling TT frames via “power units” might not benefit all players equally.
While I think that the people at Zwift might read this request and come up with a cool system, I remembered that there already is a method that more or less adapts to the rider’s capabilities: zFTP
As an example, instead of 10 hours riding for the next level, it could be required to ride "10 hours at 50% zFTP - with rate-capping to values between 25% and 150%“, or something similar. Details like limiting and scaling would have to be figured out.
To my current understanding, time at power in relation to the zFTP might address some of the concerns (to some extent) that were expressed while also allowing me to influence the time it needs to level up TT frames.
Thanks!
PS: not a native speaker. Hope I expressed my thoughts well enough.
This seems reasonable but all the other ways that people upgrade bikes also favor people who ride more distance, ride with more power, etc. If that’s unfair then the whole bike upgrade system is unfair. Personally I’m OK with it.
I’m with you on this. The whole system is great for folks who can ride huge distances or have their friends share their account (to get more distance easily). And also that all bikes, upgrades and wheels now are ridiculously expensive.
They are “mountain” bikes and you do climb up mountains. They could have made them distance based (or worse, time based), those would be bad.
Time based upgrades just benefit the folks who can spend 4-5 hours per day grinding away on upgrades, or those who share their account with a friend so they can always do 2500km/week (every week) and have upgrades done faster, or worse, use bots to grind out the upgrade distances.
I like the Power unit idea, it’s clearly better than time.
Plenty of people cheated to get TT bikes before and plenty will again. We can’t control for that and if zwift wanted to have every race be level playing field then upgrades would be neutralized, levels would be neutral, and steering would be off.
What I like about Power units is that it makes more sense going forward than time.
Why should stronger riders get rewards quicker, especially if riders are riding to their zone ability?
Zwift is giving stronger riders rewards (frames, wheels, upgrades etc.) quicker, making them even quicker in races and TTs over weaker riders in their pen, until eventually the weaker riders finally get the same rewards weeks/months/years later.
Stronger riders and people who spend more time riding on zwift should probably get rewards faster, given that’s the whole point of the reward based system.
A rider doing 10hrs a week at 4w/kg isn’t racing someone doing 10hrs or 3hrs a week at 2.5w/kg. They’d be in different cats.
In biking software I don’t think it’s odd to expect people who are stronger on the bike would be able to level up faster. If every reward was just based on time the incentive would be to just soft pedal all the time, for everything. So it’s good to have rewards for all sorts of things… distance, power, power/weight, elevation, time etc.
