Triba rc120 zwift hub compatibility check
Hi everyone, just purchased a triban rc120, just wanted to check i have got everything right and this bike is fully compatible with the zwift hub 8 speed without any adjustments. Thanks in advance.
It’s compatible, and you may need to make derailleur adjustments if the shifting is not perfect. This possibility is normal and it’s due to the minor differences between trainers and rear hubs. Sometimes it’s possible to correct the difference with the addition of a very small spacer on either the hub or the trainer. A bike shop can help you sort that out if it happens. You would need to show them both the complete bike and the trainer.
