you need to post pics of both drive side, non drive side and woth the ride on the trainer
Thank you for taking a look at it. Here are the pictures.
I can easily push the Thru Axle all the way through but then once I start turning it, it just doesn’t tighten into the threads on the non driver side. Doesn’t matter whether the frame is on or off the Kickr Core, I cannot tighten the Thru Axle.
I can screw it on from the wrong side (starting from the non-driver side) but when I try to insert it correctly from the driver side it doesn’t seem to be able to tighten on the thread of the non-driver side.
That won’t work, you need to put your chain on the cog first
