I have the new ride and just put it together. At the first ride there was noise from the axel. When I took it out it has scratch marks om the drive side some 20mm in and around the whole axel. I have tried to tighten it evenly, tight and position it carefully but the squeking is still there. There is no problem to engage the axel at the non drive side. Any advice? Do I need a new axel as it has the scratch marks?
I wouldn’t worry about the damage to the thru-axle, but it would be worthwhile to understand why it happened. Which trainer are you using? If it’s a Wahoo trainer, you should check that the proper adapters are installed, including the drive side spin cap. People often miss that one and it can result in the bike shifting around on the trainer.
Thank you.
It is the new Zwift ride so wahoo core 2. There is only two spacers\caps and they cant be inserted wrong.
Yes, trying to figure out why. First I thought it might be debri but carefully cleaned the axle and trainer. By measurement it seems to be the first part of the trainer on the drive side. Tried to fit it multiple times but still squeeks some under load, so scratching. I will try to ask Wahoo support as well.
Contacting Wahoo is a good idea.
Post a picture of the drive side of the trainer with the bike removed
Did you figure out a fix?
Mine is doing this exact thing
After one more ride the axle got more scratches. I took the cog off and there was indeed some burr in the trainer. Cleaned it up with a small and fine diamond file. Almost all of the squeak is gone. - now a few months later no noise at all.
Hey Jari and Jarron, Tom here from Zwift HQ. I’m part of the team responsible for supporting the Zwift Ride.
Superficial scratches like this are normal as on any thru-axle, trainer or outdoor bike, the tolerances between the thru-axle and the trainer axle have to be quiet tight.
Of course if you see deeper scratches this is something which Zwift support can look into. You can contact us at: https://support.zwift.com/
