I really enjoy riding but I’m not out to be a professional. I bring my road bike in during the winter to ride. It’s boring. I would like to participate on Zwift without breaking the bank.
So on my Classic trainer if I got the Garmin ANT+ Stick (ANTUSB-M) I would need a speed/cadence sensor or power meter to go with it. Any recommendations??? I want to make sure they work together.
I am also new to Zwift. It is definitely more engaging than using an indoor trainer alone.
I started by using Garmin speed and cadence sensors. These sensors were more affordable than getting a power meter. They worked just fine. Within Zwift, the speed sensor will calculate your power stats virtually. This setup will get your going.
I have found Zwift to be fun and motivating. I hope you do too!
The Garmin sensors are super easy to install. When you log into Zwift, you will have the option of pairing the sensors. Very straightforward process. You might need to spin the cranks to “wake up” the cadence sensor.
Do you have a heart rate monitor? Not required to use Zwift, but it would give you useful info for training. I use the Wahoo Tickr (there are others as well).
Awesome! You are on your way! I hope you enjoyed your ride.
I am not sure if the Fitbit will pair as a heart rate monitor. When you go to the log in screen, you could try clicking on the search button (under the heart rate monitor tab) to see if Zwift detects it.
I think that the HRM needs to be Blutooth enabled.
