when i turn on zwft and everything is paired up correctly i never get the small wrench symbol next to my paired smart trainer which would allow me to do a calibration in game , any ideas?
Not all trainers are able to do calibration within Zwift. Whar trainer do you have?
Thanks, I have the new Wahoo kickr
How are you connecting it?
Ant with a boggle in my mac book pro
It’s a 2017 kickr which is not listed on the choices in the link you sent me
It should work, make sure you are connecting it using FE-C.
Run the Wahoo utility and make sure you are all up to date on firmware. As Paul said, the FE-C version is the one to use. “Forget” the Wahoo KickR if you added it.
The wrench will be under Power Source. The FE-C will be added as both Power Source and Controllable.
2017 KickR works fine in Zwift.
Good luck!
