Hi, I have a tacx vortex and sterzo steering and looking to upgrade.
I use a alloy cannondale synapse with rim brakes.
The combo I was looking at is:
Used Tacx Neo 2T (or new elite xrt if it doesn’t work)
Elite Rizer
I have asked suppliers and get mixed messages which is understandable as it’s a Elite product ideally for Elite trainers. Does anyone know if this will work please with any experience?
I have read about the 2T not pivoting, others say it does. Some put washers or bearings in, not sure where? I like the sound of the neo 2T with freewheeling and also option of not plugging in.
Basically the axle of the neo doesn’t pivot so it’s your frame that moves against the resistance.
You can install some plastic washers which will lesson the strain on your dropouts.
You can also loosen the skewer slightly to lessen the pressure.
I’m using a carbon frame and have not had any issues so far. That said I’m not precious over the frame as it’s a spare.
The Rizer pairs seamlessly with the Neo.
There is sometimes a bit of lag between it adjusting the angle compared to what Zwift is reporting but it’s not that noticeable.
Thank you Stuart. Sounds like a go then. It’s an old bike I’m using so not worried about the frame. If you have any details on the nylon washers that will be great, no problem if not, I can find that out thanks again.
They don’t need to be big. Maybe 3cm diameter with a hole big enough for your skewer to go through. One each side of your dropouts so 4 in total. I’d put some grease on both sides too. Nothing technical, just to help the frame slide better.
Hi Stuart, what settings are you using on the rizer please?
I don’t seem to be getting the full movement ie Zwift says -3% but unless I stop pedalling it stays around -0.5% on the rizer app?
I looked at reviews, that’s a really helpful link, thanks I had the rizer and Zwift setting correct. Just changed the 100% setting in Zwift itself and perfect. Thank you
They look good but how wide are they. They look large in diameter.
Also the depth may be an issue. Not sure you’ll fit them between the trainer axle & frame.
I used 3x 10x22x.01 washers between bike and frame, greased.
Then similar roller bearing between outer frame and trainer screw/nut (5mm width but no issues as outer frame). No issues so far, however, using an older alloy frame which I’m unlikely to use in the road.
About 3mm thickness, I got a used alloy frame to build as a trainer bike. There should be enough axle on the trainer to get me at least half of the drop out on the tacx axle. I ordered both 9 and 10mm. Just got the rest of the components for the trainer bike so this will be going down very soon.
