After an update on my smarttrainer Taxc Flux S the resistance does not agree with the slope. On a flat stroke my smartrainer thinks there is a slope. On a slope it is sometimes the opposite.
Callibration those not work either. Other cycling apps are working good, only a problem in Zwift.
Almost one year there were no problems. Just after the update from Taxc.
Hi @Benjamin_Terpstra_PA welcome to Zwift forums.
Are you in a workout using ERG mode? Or a free ride in simulation mode? If you’re in a workout, things are working as they should.
If you’re in in ERG mode, the workout sets a wattage target that you’re trying to hit. The slope of the hill will not play a role in the resistance you feel in ERG mode. Some more information about this on our Support Hub.
It’s only in Simluation mode when the the resistance will match the slope of the hill.
Also: it’s generally better to calibrate your trainer with the manufacturer’s app instead of Zwift.
