TACX Cycleforce flow T1682
Hi can you confirm if this trainer is supported by Zwift and if so which trainer should I select from the menu
Hi @Mark_Jefferies8411
Welcome to the forum.
See this list of supported trainers. What You Need To Ride
Thanks Gerrie
I also have a tacx blue matic, which altho supported is limited in power due to having to set it at level 3 on the trainer. Is there anyway around this
Thanks Mark
No there is no way around the power limit in some classic trainers. Zwift chose these limits due to accuracy concerns. There is some other trainers with higher limits.
