What Trainer Should I select on Zwift if I’m using a Tacx Flow T1680?
I don’t think that trainer is supported.
What system do you use for Zwift?
You can try to plug the usb cable into the Pc (if you use a pc) and see if you can select power source in the pairing screen.
You’re correct @Gerrie_Delport, it’s not supported, but do you have a suggestion for the best trainer setting to select?
Hey Zwifters!
I’m using the T1680 as well, anyone found good settings to get the best and realistic results?
I’m just new to Zwift so any help appreciated.
Ride on!
