Hi Swifter,
my software crashes all the time.Below the logs. Anyone has an idea?
Processor Snapdragon(R) X 12-core X1E80100 @ 3.40 GHz (3.42 GHz)
Installed RAM 16.0 GB (15.6 GB usable)
Product ID 00356-06299-04087-AAOEM
System type 64-bit operating system, ARM-based processor
[7:25:07] Chat: Kino[JBC] 6950750 (World): ではこれで失礼します
[7:25:10] [INFO] Auxiliary Controller attempting to connect to phone at: 192.168.170.132:21588 (secure)
[7:25:11] TimingArch: (Fuego Flats Reverse) passed checkpoint 4
[7:25:12] INFO LEVEL: [BLE] “Zwift Click CFC2” battery level: 70%
[7:25:13] FPS 47.32, 38858, 11846, 407333
[7:25:14] [Route] Hit checkpoint 139 out of 169 on route: " Tempus Fugit"
[7:25:15] [WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[7:25:15] [INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[7:25:15] INFO LEVEL: [BLE] “Powrlabs_0699006” battery level: 100%
[7:25:15] Chat: Shinkai 6178782 (World): おつかれさまでーす
[7:25:17] INFO LEVEL: [BLE] “Zwift Click CFC2” battery level: 70%
[7:25:21] FPS 46.08, 41821, 11846, 401640
[7:25:23] INFO LEVEL: [BLE] “Zwift Click CFC2” battery level: 70%
[7:25:26] [INFO] Auxiliary Controller attempting to connect to phone at: 192.168.170.132:21588 (secure)
[7:25:27] [Route] Hit checkpoint 140 out of 169 on route: " Tempus Fugit"
[7:25:28] INFO LEVEL: [BLE] “Zwift Click CFC2” battery level: 70%
[7:25:29] FPS 47.85, 44844, 11846, 395864
[7:25:31] [WARN] Auxiliary Controller failed to shut down tcp socket: ‘A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied.’ (10057)
[7:25:31] [INFO] Auxiliary Controller failed to connect to socket: ‘The I/O operation has been aborted because of either a thread exit or an application request.’ (995)
[7:25:35] INFO LEVEL: [BLE] “Zwift Click CFC2” battery level: 70%
[7:25:35] GL_FRAMEBUFFER_UNSUPPORTED
[7:25:35] GL error GL_OUT_OF_MEMORY
