Suunto HR issue
Hi all
Cannot get my suunto Hr monitor to work has anyone had this issue or is it just me.
Which Suuto HRM?
What are you running the Zwift app on (PC, Mac, iOS, ATV, or Android)?
How are you trying to connect (Bluetooth or ANT+)?
Has it connected before?
More info is needed to assist you in resolving your issue. Feel free to add additional info that you have
Suunto Duel
Using I pad
Does connect to my watch but not zwift
Ant or Bluetooth don’t know sorry very new to this
Sorry Suunto Dual
Ok, it looks like the Suuto Duel only broadcast in ANT+: https://ns.suunto.com/Manuals/Comfort_Belt/Userguides/ComfortBelt_userguide_EN.pdf
The iPad will on receive Bluetooth signals.
You have a couple options in getting it to connect:
  1. Use CABLE to bridge the ANT+ signal from the HR Monitor to the iPad
  2. Use a Duel Band HRM like the Wahoo Tickr
Looks like there might be a couple different versions on that HRM, can you tell me the model number of the one you have.
Thanks for all your help much appreciated
The Hr strap was faulty now sorted
HI, I also have the problem that my Suunto HR strap is not seen… I use strap no. SS020566000
I have the Wahoo Kickr connected with iPad. Is there a Hr strap from Suunto that acually works?
Thanks a lot for your help.
