Stuck during log in
Yesterday everything worked fine, today when i was logging in it gets stuck before connecting my trainer. I have reinstalled but same issue, it´s on a SSD disc.
Someone have any idea what it is?
The program is on the SDD and you’re trying to run it from there or you’re installing it from the SSD?
Can you share more details about the PC?
When you reinstalled, did you go through this process? Re-Installing Zwift
You could also try removing %TEMP%\..\Zwift\launcher\webview
Its installed on the SSD
Meaning the SSD on your computer? Usually the C drive.
My SSD is H:, tried to reinstall it for the third time now following all the steps with the same result, have been flawless until today and have done nothing to my computer since yesterday.
Intel Core i5-4460 3.20 GHz
16 GB
NVidia GeForce GTX 1050 Ti 4GB
Can you be more specific about what is happening when you say it gets stuck? Any error message, what screen are you getting to? Does it crash to the desktop or sit at a screen?
Everything moves like one step every 3 minutes when i get to login and the bike is going out to the left, have been waiting now for 15 minutes and now the bike is gone and waiting for the connect equipment window
if you have an ANT+ stick plugged in, close Zwift, unplug the ANT+ stick, wait a few seconds and then plug it back in. Then try Zwift again.
That worked, such an easy fix :D, ty very much for your patience <3
