Struggling to hit 'Build Me Up' RPMs
hey guys - loving my early experience of Zwift. Quickly chose Build Me Up program to give me a structured way to learn the game, train hard and get going.
Using a Direto smart turbo and a gravel bike, I’m on about the 5th workout now, done week one, and clearly lots of the BMU program is about cadence/RPMs.
While I’m hitting Watts via gear changes, I’m way WAY off the RPMs. Typically I’m at around 60-70 rpm.
If the turbo is on ERG mode (because Zwift is operating the program), should I be able to stay in any single gear, and just up my cadence to the target RPM and let the turbo/Zwift manage the Watts?
I’m finding that if I increase my pedalling speed, Watts go up and RPM is being levelled out/steady. So I’m being told to reduce power but increase cadence. If I drop gears, it doesn’t seem to get better.
Basically - as you can see, I’m pretty confused :slight_smile: Help appreciated.
Hi @will_mc,
If you put your workout in ERG mode, that means Zwift will control the trainers wattage regardless of RPM. That is a great way to stay of target wattage in Build Me Up (BMU). I did the plan twice last winter, and it greatly helped with FTP increase and cadence IRL.
Basically if you do 200W at 70RPM, and you up the RPM to 90, than your wattage will go up too (same gear + higher RPM = higher output power). Basically in that case if you should keep the same 200W but on 90RPM instead of 70RPM, you have two choices:
  • in SIM mode (when Zwift doesn’t control your trainer) change to easier gear to balance out the higher RPM (so change to bigger cog at the rear)
  • in ERG mode you have to do nothing. Zwift will tells to your trainer to give less resistance.
In the second case (ERG mode) you’ll see your wattage increase initially when you jkump from 70 to 90, but within 5-10 seconds (probably tad more, I’m not familiar with the Direto) you’ll see your watts “drop back” to 200W while keeping at 90RPM.
Please note that NO CYCLIST CAN KEEP exactly 90RPM. As your cadence varies between 87-93, you’ll see fluctuations in wattage because when your RPM drops below 90RPM, Zwift increases the resistance on your trainer, and when you spin up and overshoot to 93RPM, Zwift will decrease resistance (needs a few seconds to happen, as mentioned).
When somebody says that his trainer stays exact wattage when his cadence goes around 90RPM (in the example 87-93) that’s simply NOT TRUE, the trainer simply smoothing out the numbers what Zwift recieves. Typically Wahho trainers were notorious for that, but in the later firmware they changed them so they aren’t smoothing that much.
You can see the effect even during warm up (jump to 28th minute) in my video of BMU’s Amalgam workout in the video:
THe RPM and wattage reported by Power2Max NGEco power meter, and the smart trainer is a Neo 1st generation.
KR,
ANdras
Andras! That is SOOOOO helpful, thank you! I’m excited to get back on and put this into action.
Much appreciated from the UK :raised_hands:
YW mate :slight_smile: One more note: when you see FTP or above FTP parts in BMU, spin up the RPM to above 100 3-4 seconds before you cross the gate :wink: Makes your life easier, and helps to avoid the so called Spiral of death in ERG mode :wink:
that last point is super important – it’s way easier to overshoot on the cadence and bring it down than to undershoot and have to rev it up. it’s a bit of a mental game getting the RPMs up, especially if you are used to grinding. i’m a bit of a low-RPM grinder, and it’s been hard work to get my cadence to be higher and feel “natural”. be prepared to take a hit on breathing and heart rate in the beginning – your body will try to force you back to low RPM!
the spiral of death is real, though – so keep that cadence up!
yikes - as a fellow low RPM grinder, this sounds hard! thanks for clarifying though :slight_smile:
Hi this was helpful, but I find I’m pedalling like a lunatic to get the watts. I have a TacX Neo 2T, I’m in ERG (FTP 130ish) I’m doing the same course too, having lost significant fitness. I’ve in fact ‘slowed’ at the Arc, to get a bit more resistance to enable me to acheive the watts…otherwise my legs are going like the clappers. Must be hilarious to watch. What am I doing wrong? I’m trying to maintain a cadence of around 75 - 80 ish otherwise my legs feel flappy, i.e. spinning with insufficient resistance. Any help appreciated. Also I’m about to start week 4.
Do you feel the resistance changes when the power targets change during the workout? Can you reach the power target at say 90 or 100 RPM cadence?
How does it compare to when you do a free ride but try to achieve the same Watts and cadence as in a workout? Same problem?
What is the gearing on your bike (front chainring sizes and cassette)? Are you shifting to a higher gear when you find it difficult to hit the power target at the recommended cadence?
Hi Paul,
Firstly my mistake, I’m doing Back to Fitness. This morning I did Week 4 ride 1/2. This focused on low rpm, but higher power. It frequently told me to lower my cadencd so I eventually got into a rhythm but, I had to increase my bias to 110% to get the slower rpm to acheive watts.
Do you feel the resistance changes when the power targets change during the workout? Yes, but usually on if I pedal a bit slower. If I go off at the Arch like a bat out of hell the watts tend to drop and there’s too little resistance.
Can you reach the power target at say 90 or 100 RPM cadence? No… :smile:
How does it compare to when you do a free ride but try to achieve the same Watts and cadence as in a workout? Same problem? Much more resistance on a free ride, far easier to maintain cadence. However when I finished my workout I continued in the same map and on hills I was at a much higher watts at slightly higher rpms.
What is the gearing on your bike (front chainring sizes and cassette)? 50 / 11
Are you shifting to a higher gear when you find it difficult to hit the power target at the recommended cadence? No. I thought the ERG did it. If I change gear it usually ‘adjusts’ it again.
It sounds like Zwift is successfully controlling the trainer. The gear you use will determine the flywheel speed even in ERG mode. I’m unsure if your gear choice is affecting your experience but it is possible that you would get a different result by using a different gear. In ERG mode, trainer resistance is unaffected by hills so the map doesn’t matter.
(I didn’t find an article on this specific to the Neo 2T but you might inquire with Garmin about gear choice when using the Neo in ERG mode)
