I ride with sram rival 12 speed on my bike, can I drive with the 12 speed on the zwift hub trainer?
Or do I have to buy a xdr body and sram cassette?
Thnx
Thnx
SRAM and Shimano 12 speed cassettes do not have the same spacing. It probably will not work very well. There are some third party manufacturers (eg, ZTTO) which offer SRAM compatible cassettes for the Hyperglide freehub body. I havenāt tried one but my nose says they are probably not great quality. The genuine SRAM cassette will probably work better. Iām not sure if the XD/XDR freehub body is actually available yet. It doesnāt seem to be sold on the Zwift website, and the Jetblack website says ācoming soonā.
Hi Johan,
Paul is correct, you can use the cassette on the HUB trainer but itās not going to shift as smoothly as your bike does when you are riding outdoors. I would reccomend purchasing the JetBlack Volt XD-R freehub body and installing a matching cassette to the one on your wheel on the HUB. I linked an example of a retailer who carries the freehub body but a quick search for JetBlack XD-R freehub body driver should bring you to a local online retailer.
These seem to be sold out everywhere I look. Are there any other options or places in missing?
[quote=āTyler, post:4, topic:591305, username:Tyler_Manningā]
[/quote] Hello everybody, i have the same problem than Tyler, i live in france and this freebody hub is not available,
are there any other solutions?
thanks
Hey Leonard -
I spoke with folks at JetBlack to try and obtain one or get an idea of when they would be available and was told there was nothing they could do because - even though its the same product - its a Zwift product, not Jetblack and they suggested I speak with Zwift.
I spent several hours in chats with Zwift yesterday and basically got word that there is no answer
"I understand this is frustrating because Iām sure you want to get riding as soon as possible. Since the product youāre referring to is not produced or offered by Zwift, we have no official āfixā or āworkaroundā for it.
It seems that, without searching the internet for either the correct part or a fix maybe another member has figured out, Iām afraid you will have to wait for the part to become available."
It was suggested just to find my own un-official solution and/or just wait for the product to become available. There is a reddit post that discusses this issue as well and some folks seem to suggest just using the stock options until the parts become available.
As far as I know, the only option for the Zwift Hub is the SRAM PG-1230 cassette, but it has 11-50 gearing so itās not a great choice for a road bike, unless you adjust the derailleur to stop before reaching the largest cogs. You may be able to use the first 9 or 10 of the cogs on it with a road setup. The gearing is 11,13,15,17,19,22,25,28,32,36,42,50. So it has large jumps in the high gears.
Did you try with the original 11V cassette?
Doesnāt he offer the 12V sunrace cassette over the counter?
The Sunrace 12 speed cassette has Shimano spacing. It may sort of work with SRAM but probably not very well. The PG-1230 is a SRAM 12 speed cassette designed to fit on a Shimano freehub.
I also have a SRAM Rival setup. I was lucky enough to source a JetBlack Volt XD-R freeehub. I bought the last one in stock from Universal Cycles in the US. Iāve installed it correct (correct torque, etc), and Iām getting some vibration in the harder gears. It happens in cogs 10-12. Iām wondering if this happens to anyone else with a similar setup or with the sunrace cassette.
I just got the hub and put on an nx eagle HG compatible cassette I already had. Had to adjust b screw a significant amount and while shifting improved I to am getting a bit of grinding in high gears. Do you by chance run the spacer with the XD cassette? I know it is required to run an eagle cassette on an XDR free hub. Zwift site says itās not required for a 12 speed cassette but I wonder if it would improve chain line a bit. Also of note without spacer I found that the trainer casing interferes with the upper derailleur pulley when trying to shift into the dinner plate. Shouldnāt be an issue but something to note.
I am not using a spacer. Iām using the SRAM 12 spd XG-1250 10-36T cassette. I did add a little more freehub grease to the pawls, and it seems to be slightly better. I might try even more grease.
Greetings! Not the original poster here, but just thought I might give a derivative on why this cassette choice might be important. In my case, I have two trainers with my road bike (Cannondale Synapse Carbon) set up on one trainer, and my recumbent trike sitting next to it on the Zwift Hub.
My recumbent trike is a heavily modified Catrike 700 running SRAM Force eTap with the 10-50 cassette in back. Iāve operated with a standard road bike 10-33 before on the trike. Trikes are significantly more difficult on long uphill rides, so that gear range is not the most pleasant experience. The 10-50 allows a massive range of gears, and the ability to stay at 18+ mph up short hills, with sufficient speed and gear prep.
Like the original poster, I just ran into the whole freehub fiasco. Iāve sent a note off to Zwift Hub tech support looking for a solution. If necessary, Iāll just switch trainers since the TacX Neo 2T the road bike is using already has the necessary components. The only problem with that trainer is that the angle of the legs interferes with the chain on a recumbent - even rocking a short cage on the derailleur. Thatās what I was hoping the Zwift Hub would solve for me.
Hello,
First off, Iāve come to find out that the preinstalled SunRace cassettes on Zwift Hub are not compatible with SRAM Flattop chains. Not a huge deal, but then I learned thereās no option to swap the preinstalled Hyperglide freehub body for a XDR compatible freehub body. So those of us SRAM AXS Rival/Force/Red users are completely screwed?
Secondly why does Zwift state in countless places on their website that Zwift Hub is āSRAM-compatibleā when thatās at best, partially true? If Zwift Hub is not compatible with Flattop chains and/or XDR freehub bodies, shouldnāt that be mentioned somewhere? Anywhere?
Lastly, why does Zwift showcase a bike running a SRAM Rival AXS groupset if the Flattop chain and/or Rival cassette (with XDR freehub body) are not in fact compatible with Zwift Hub?
It seems like the only solution is to buy a JetBlack XDR freehub body, but theyāre completely sold out. Zwift, why donāt you sell/provide a XDR freehub body?
Sincerely,
Greg with a $500 giant paperweight
My guess as to whatās going on hereā¦
Where to from here�
Both of the above may involve having to pay license fees to SRAMā¦
tldr; Itās just an awkward position of differing āstandardsā and Zwift selling a really cheap trainer. Iād love to see a better solution.
My guess is they just donāt have availability of that part currently, as JetBlack has it on their website ācoming soonā.
But none of this explains why they recommend that a rider with an XD/XDR bike should buy the Hub sans cassette, because they wonāt be able to install it.
Are Sensah cassettes compatible with SRAM AXS 12sp? I know a couple of pretty reliable folks who have found their complete Sensah groupsets to be surprisingly okay. I know they make 12sp HG cassettes, 11-28/32/34. Not sure if they play nicely with AXS.
Hello Michael,
Can you tell me about the installation you did?
I canāt adapt the freehub body xdr with the cassette, the thru axle which is screwed does not retain the cassette ā¦
How did you proceed?
thank you in advance,
LƩonard
