Sort workouts by time and effort - within Library’s
With the changes to the Workout Library last year, is it possible when searching for Workout in each category there is an option to sort the workouts by length, effort and TSS score? E.g. in VO2 max library for example you can sort the screen by the length, effort and TSS score. This would be a useful feature to help find work outs that match the time you have to work out or the effort you want to do?
Welcome to Forums. Thank you for using this space to share your thoughts. This is Juan from Zwift. With the latest changes, the workout library can be sorted by duration, elevation, distance, name, effort, and route completion. Do you mean something like a subcategory once you have already chosen category?
Anyhow, please feel free to share your feedback so we can continue to level up the workout library in the future. To share feedback, check out this post on our forums.
Hi Juan, thank you for your reply. I can see that all workouts can be sorted by duration and effort. Although I could not see the elevation, distance and name options you referred to. My point was about being able to sort within a sub cateogory (e.g. the endurance collection sub category) and also for this sorting to be from shorter to longest or easiest to hardiest. So if you only had 45mins to work out you can quickly scroll down to all the workouts that are around 45 mins. For the current filtering of all workouts, if you for example you select duration and 30 - 60 mins and effort easy you get 117 work outs which is a lot to scroll through and pick the work out that works for you. I hope that makes sense? Thanks
Hi Juan, I was just wondering if you saw my reply? I tried the link to the other forum and whilst I can see it there does not appear to be an option to post new feedback? Has this forum now closed for new feedback?
That thread is locked so you can’t add to it.
Hi Juan, I was just wondering if you saw my reply to your previous message? Many thanks. Richard
Copying my previous reply for ease.
I can see that all workouts can be sorted by duration and effort. Although I could not see the elevation, distance and name options you referred to. My point was about being able to sort within a sub cateogory (e.g. the endurance collection sub category) and also for this sorting to be from shorter to longest or easiest to hardiest. So if you only had 45mins to work out you can quickly scroll down to all the workouts that are around 45 mins as you can order the workouts by time. This would be a useful addition. Likewise being able to sort by effort in a sub category would be useful. For the current filtering of all workouts, if you for example you select duration and 30 - 60 mins and effort easy you get 117 work outs which is a lot to scroll through and pick the work out that works for you given they are also in alphabetical order. I hope that makes sense? Thanks
