When you arrive at a crossroads and you select the direction where you want to go, the cyclist should point the direction with his arm, in this way it would be easier to follow someone with whom you are following.
There is already a visual indicator with flashing arrows behind the cyclist if they are turning left or right.
I did not know it until now I have not seen it. I look good. thank you very much!
¡de nada!
