Just noticed my setting options on Apple TV are fewer than on MacOS. For example, Zwift on Apple TV does not show Trainer Difficulty. Nor it shows Tacx Neo Road Feel. Does anybody else have the same issue?
It should still those. Check that you definitely pair the trainer as Controllable as well as Power.
thank you! double checked and triple checked. Both are paired and recognize the trainer as Tacx Neo 2T.
the problem is solved. I deleted the app from the Apple TV and re-installed it. All the settings are now back on
