I own a Garmin 235 (watch) and a Garmin 710, I have tried via bluetooth and leads but they don’t want to talk to one another. Any tips on getting this to work please?
You need at least a speed and cadence sensor to use Zwift. Just a watch will not work and the Garmin 710 is about useless for Zwift.
So can I buy a speed/ cadence sensor for the watch?
Ok, lets start over.
What are you trying to accomplish?
I wanted to have a go at Zwift. As I have a couple of Garmin products i’d hoped they would connect up and I could start making use of the 30 day trial.
You need to have a least a Speed and Cadence sensor to use Zwift. Garmin has them and so does Wahoo along with numerous other manufactures. You could also use a power meter or a smart trainer. Basically you need something that can measure your wheel speed at a minimum or your watts if you want more accuracy.
You will also need a Ant+ dongle or bridge Blue Tooth through your phone to your PC.
http://www.titaniumgeek.com/cycling/zwift-user-manual-unofficial-running-updates/
Thanks for you patience with this. So basically I can by-pass the Garmin and have a direct link between my laptop and the cadence sensor?
Yes, but you would need an Ant+ dongle in your PC or if it is Blue Tooth you can use a phone to bridge the connection to your PC.
Thank you. For now i’ll just get the Ant+ dongle and Cadence Sensor and go from there.
