Score not showing up on League
Hi There,
I Raced the first 2 races (Cat E) of Punchy Power (Zwift Labs) but cant’s find my score on any league…
Can anyone help?
Thanks in advance"
Here are my Races links:
Hard to believe, but because the 1810 BST and 1910 BST Racing Score zmonthly races use different pen ranges compared to “non-primetime,” they don’t get a league on zwiftpower.
But is this some kind of fixable mistake/bug, or is it on purpose?
Not a bug. The high-end and low-end races can’t work for GC with the rest of the zRacing events as it’s based on the pen letter. High-end D, low-end D, and D pen in the 5-pen ZRS races and CE races would all end up together.
They decided to make one GC league for the CE races and another for the 5-pen ZRS races. They decided to not make one for the high-end or low-end races.
200/400/600/800 score should have been the standard Racing Score zmonthly thresholds for promotion to pens D-A, given Racing Score is essentially a 30sec power pen allocation system.
But instead, we have 0-285 as the standard Racing Score range for E, inviting racers from Category Enforcement mid C to all of D into the pen meant for the weakest racers. With 0-200 for the 1810 and 1910 BST.
The wide range of CE Categories showing up in a ZRS pen isn’t unique to the low end. Plenty of C’s have scores over 600 and are competing against A’s. Not only C’s who might be holding themselves back to avoid an upgrade. Some of us are just very heavy. But that’s really a discussion for a different thread.
They would have to create a league that only included the Zwift Labs events, which they could do, but chose not to.
Oh, but they did… unless I’m mistaken, they do have ath the end of the League List this:
Zwift Labs - July
Zwift Labs - August
The funny thing is, I DO appear on July with ONE appearance, but none on August… So maybe something changed?
That’s good news. Contact support and ask if they missed the updates.
I’ve also raced two races. One on the 30.07 and the other yesterday 06.08. Only the one from yesterday is showing up in the Zwift Labs August Leagues results.
Results for other riders from the 29-31.07 are showing up so it doesn’t appear to be caused by the change of month. How can I get that fixed?
I believe the one you raced on 30.07 was a race using LOW end.
As seen in a post above It appears Zwift do not wish to use the LOW or HIGH end races.
Zwift did use LOW and HIGH end races 18:10 from 19th - 29th July in July Labs league.
Other than a LOW end race on 31st [corrected] July (IMO a mistake) it does look like Zwift is not using them for August Labs league.
Well if that was the case, there would be no riders on the August E Cat league, would it?
But there are…
Not sure if I understand your question correctly.
Doesn’t the August E Pen results come from the 0-285 ZRS racers from the Labs ‘using racing score’ races where only 5 pens are used.
If the race covers ZRS range 0-1000 over 5 pens it counts BUT if 10 pens are used neither count [ 18:10 HIGH & LOW races don’t count ]
Yeah, makes sense as I stepped up a category for the second race. All a bit complicated at the moment. Thanks !
