Samsung Tab S6 - install error
Hi
Really disappointed got a shiny new tablet went to install zwift from play store and I get an error - file missing please reinstall I’ve done this many times but no solution
Is there something wrong with the APK in the play store or compatibility with samsung android tablet ?
Thank you for any help
Jim
Hi @James_Gillespie welcome to Zwift forums.
The Samsung Tab S series are known not to work. The Android FAQ has more information.
Thanks @shooj for your comment.
The Zwift website says if you can see the app on the Play store it should work ?
|Device|Requirements|Notes|
|Android®|* Android® 7.0 or higher
  • Arm64-v8a ABI (Arm64 architecture)
  • At least 1 Gig of Ram
  • OpenGL ES 3.0 or higher|
If you’re not able to find the Zwift app in the from your Android® device, it’s not compatible with Zwift."
hi i have used tab s6 for over a year and no issues what so ever just ensure no other blue tooth devices working and location is on when using
@James_Gillespie
There’s this bit lower in the Q&A’s.
Thanks Will. The Tab S6 is a recommended device so should work
Did you ever get this sorted James? Having a smiliar issue with a pixel tablrt
Hi Chris,
Is this still an issue for you?
Diarmaid
