Hi, i was wondering if it’s possible to use Zwift with my Samsung Galaxy A12?
I have the zwift partner app. But i want to zwift on my phone. Thanks
Have you tried installing it from the play store?
Generally if you can install it then it will work.
Zwift has an FAQ on this - see Supported Devices to Run Zwift
But short answer is yes I believe the Galaxy uses an Android OS right?
If so then as long as the A12 has:
then you should be fine. The FAQ seems to suggest if you can see the app listed in the Google Play Store, that means your device is supported.
