Hi.
Seems to be no resistance on hills today ans yesterday when i rode on my smart trainer. Its connected to my pc via the tacx ant+ dongle. Do you have any solutions for this?
Alex
Hi.
Alex
Hey Alex,
In checking your account a bit, I noticed you don’t have an FTP set and that can affect the amount of resistance you’re feeling in-game. When you have a bit of time to spare, please try completing an FTP test and if you’re still noticing a lack of resistance, please open a support ticket with us or let us know here.
Hi.
Thanks for the answer, il try that although i had noticable difference in resistance during my trail periode. It just suddenly didnt work on friday.
Hey Alexander,
I’m thinking that’s just coincidental. I don’t see any differences in pairing between when you used to be on a trial and pairing after signing up for an unlimited membership aside from adding in a Heart Rate Monitor.
Now that I take a closer look, I have more of a feeling this is an issue with your FTP because I can see you used to have one set. When you were on a trial, your FTP was 230, but now it’s set to 0.
Hi. Just got a Tacx Flow Smart recently from a friend. He got it new from warranty about a year and a half ago and just used it once. Unfortunatelly I feel no resistance. I’ve been using Zwift but already tried Tacx App and RGT and I feel no resistance also.
I connect my trainer with an iPad Air via Bluetooth. I have never had a problem connecting it.
@Miguel_Silva1 in the pairing screen I assume you are selecting the Tacx Flow as a controllable trainer as well as the power meter? Is the Flow connected to any other source as a controllable trainer that may be overriding Zwift?
Yes! Zwift detects the trainer in a few seconds as controllable trainer.
Trainer difficulty set to the maximum.
The lack of resistance also happens in Tacx Training and RGT. Tested in an iPad Air and in a Surface
It’s not possible to use another app at the same time since it won’t recognize the trainer
Have you downloaded the Tacx Utility App to see if there is a firmware update available?
Yes of course. I check for updates every time I use the trainer. I believe there’s something wrong in the resistance unit
If it’s not providing resistance even through the Tacx app you will need to reach out to Tacx/Garmin directly as that indicates an issue with the trainer itself and not Zwift.
Good luck and hope it gets sorted for you quickly.
