Has anyone else had an issue with their rear derailleur rubbing against their trainer when in their lowest gear? I have the H2 from Cycleops and the 6800 Ultegra groupset and I’ve checked all my alignments, everything is fine and it shifts well; using the same cassette as on my actual bike.
I contacted Cycleops and their response was “Long cage derailleurs like your Ultegra can rub on the casing on the H2, there is unfortunately nothing we can do to make it go away. I apologize for the inconvenience.” Less than helpful :-/
Is the best solution to lower the resistance in Zwift and just not shift into the lowest gear?
Thanks!
