Problems with IOS connection
**THIS POST ALSO FILED ON OTHER THREADS IN “BUGS AND SUPPORT”
Hello Legion of Frustrated Zwift/Saris H3 riders:
Like you, I have experienced the same annoying BT drops to the H3 trainer on Apple devices since my iPad and iPhone installed iOS14.2. Since neither Zwift nor Saris have yet been responsive to trouble tickets, I decided to design some controlled experiments to diagnose the problem. This is the report of my first experiment…there will be four more reports over the next several days, so stay tuned.
Looking deeply into my Zwift ride files and other electronic data that I was able to capture using independent test equipment, the BT drop appears to be related to use of the Zwift Companion app (hereafter “ZC”) with the Device Connection bridge switched ON while the Zwift game app (hereafter “ZG”) is running on an iOS14.2 device.
Hypothesis: After iOS14.2 installation, something broke with the ZC Device Connection bridge, thus causing interference with the BT connection between the H3 and ZG.
Experiment #0: Can a stable and responsive BT connection to the H3 be established and maintained outside of ZC or ZG? Method: Directly connect the H3 to the Saris app or Rouvy app (on iPad Gen2 running iOS14.2). Success! BT connection maintained and both apps able to communicate reliably with the H3. In addition, I was able to ride in Rouvy without any BT drops.
Experiment #1: Can a stable BT connection be directly established and maintained between the H3 and ZG with ZC not running on any iOS14.2 device? Yes! I was able to directly connect the H3 to ZG running on my iPad (Gen 2 with iOS14.2) via direct BT link. Thereafter, I was able to enjoy a one hour group ride on ZG without a BT drop to the H3 for the first time since my Apple devices installed iOS14.2. Full disclosure: I usually run ZC on my iPhone and ZG on my iPad (larger screen) with both devices active on the same WiFi network. For this experiment, I switched OFF the iPhone BT and did not activate the ZC app in order to create the cleanest possible experiment free of any competing BT traffic.
OK - So it’s unpleasant to not be able to message anyone using ZC during a ride or to not be able to switch to Map or Dashboard mode in ZC, BUT…not as unpleasant as having your avatar stop moving because the BT connection to your H3 was randomly dropped in the middle of a ride.
NOTE - If you are up for it, please try Experiment #1 above with your Apple device/Saris H3 setup and report your results back to this thread. The wisdom of the crowd may help solve this issue long before Saris or Zwift offer a response.
Subsequent planned experiments over the next few days:
Experiment #2: Establish direct BT connection between H3 and iPad (running iOS14.2). Turn on iPhone BT switch, BUT do NOT start ZC app on iPhone. Join a group ride of at least an hour. Design: Attempt to determine if BT interference is coming from another radiating device, or from the BT bridge in ZC.
Experiment #3: Establish direct BT connection between H3 and iPad (running iOS14.2). Turn on iPhone BT switch, AND start ZC app on iPhone but without having BT bridge active. Join a group ride of at least an hour. Design: Attempt to determine if BT interference is coming from the BT bridge in ZC.
Experiment #4: Establish direct BT connection between H3 and iPad (running iOS14.2). Turn on iPhone BT switch, AND start ZC app on iPhone with BT bridge ON. Join a group ride of at least an hour. Design: Attempt to determine if BT interference is coming from the BT bridge in ZC.
The above experiments are designed to use a step-by-step approach to re-introduce sources of BT interference between the H3 and ZG and ZC running on an Apple iOS14.2 device UNTIL I am able to replicate the BT drops that everyone has observed. This approach should isolate the source of the problem, and reveal a workaround until such time as Zwift or Saris fix the bug.
That’s a masterful response, Scott.
I’ve been having issues with BT connectivity using a dumb trainer and a Wahoo SC cadence/speed sensor mounted on my bike frame. It just started recently AND, coincidentally, I’ve been using the Zwift Companion app more frequently for meetups and the other perks it offers.
It’s a premature conclusion, perhaps, but it really seems like something broke between iOS and the Zwift Companion / Zwift client interactions.
I’ll try riding with just the Zwift client on an iPad to see if that resolves the BT dropout problem. Your deconstruction of the possibilities helped me see this is a likely source of the trouble.
