Not sure if this is in the works but I’d love to know if it’s a feature that’ll be out soon.
I’d like to be able to connect two power meters to Zwift one as the controller just like normal and the other as secondary for dual Recording which can’t be used it’s simply supplying data only so both fit files are there in game.
This means Zwift will no longer need to request secondary files and makes it easier on the riders having to muck around with sending it in as well.
It also means after a ride you can instantly see dual
Recording data if another screen option was added at the same time.
A simple dual record tick box on the pairing screen opens up a secondary search screen once the controllable is connected.
