Can I pair my Garmin Forerunner 225, with wrist heart rate to the Neo smart trainer?
I tried but the searching device didn’t turn out anything. The blue tooth on Forerunner 225 is switched on.
The Forerunner 225 is not a supported device within Zwift.
Hi thanks for this answer, does it mean that that Garmin Forerunner 235 is also not supported by Zwift? Or should this work?
If it can broadcast an Ant+ signal (or BLE, it’s Garmin so I doubt it) then it should work now.
Per Zwift:
Zwift supports all of models on the market that connect via ANT+ or Bluetooth Smart (BLE) using open standards.
Edit:
After doing a quick internet search I believe it will work.
Yes, that’s super-helpful. There is a way to broadcast the HR using ANT+ - but it doesn’t hang off the main settings menu!
Anyway, I’m all connected up now. Thank you.
Hello, which dongle do you use? I have the same problem, my Forerunner 235 i broadcasting the heart rate but i can’t pair it in the swift menu as heart rate source.
Please help me! Thx
