Orange bar icon next to my zwift bike rider
Hi
Today on my zwift ride, for the first time whilst racing, i had an orange bar like icon next to my rider avatar on his right side for all the race. Is it something to do with the zwift ride steering? Or direction im going? I tried using the left & right levers to get rid of it?
Cheers
If it’s what I think it is, it only appears when you’ve steered as far right or left as the route allows. It being permanently on might indicate an issue (avatars always drifting right has been seen by others). I would check that your Zwift software is up to date and also the firmware in your Zwift Play controllers.
Thank you very much, i will try all what you have suggested. I never touch the left & right steering so seeing this permanently there & then I used the levers to try & rectify it unsuccessfully.
Thanks again
Hi @Lee_Quantrill ,
Welcome to the forums! Jose here, from Zwift.
I want to share this article with you where it explains each of the symbols that may appear in the game so that you can be familiar with them and I also recommend that you keep the game and your controls on the latest version of the game.
If you ever need help, remember that you can contact us atsupport@zwift.com.
That article doesn’t contain the answer to this question, but maybe it should.
I suspect @Lee_Quantrill has a faulty steering device but checking firmware, doing a reset of the controls, and calibrating the controls should probably be tried before getting a replacment set.
