When I log in from my PC, I do not have a choice to ride in Watopia. Only NY, London, Yorkshire. When I log in from ipad, I can ride Watopia but not my PC. Has anybody else seen this and what is the fix if any?
Sounds like you edited your Zwift prefs.xml file at some point or used a tool that did it for you?
If so, you need to rename or delete the file. Zwift will recreate it when you start the app. That should fix your problem.
Makes sense. I’ll look into that
-Chuck Blasi
