Hi all,
Anyone else have a sound issue when your ride video clips have been uploaded?
I have no sound in any of the clips (going on2 weeks now) and also some clips only play on Strava for like 5 or 7 secs and then go back to the start)
Was expecting a seamless upload since I got my G3 Apple TV.
My game play sound setting is mid level.
Anything I can do to fix it?
Thanks in advance.
Mine have sound, but I’m not on Apple TV.
There was a previous report like yours some months ago.
Video Screenshots from my AppleTV save with no sound. Is this normal, or is something not setup correctly.
Keith
There was also a report of truncated videos on Strava. I don’t use Strava so I have no direct experience with that.
Not a Zwift issue per se… but wondering if anyone else is having this problem and/or has a solution.
Running an M1 Max MBP. Video screenshots uploaded to strata stall on playback at the halfway point. I can generally manually scrub through the second half of the video and see content, but normal pl…
Thanks Paul, I’ve deleted Zwift and reloaded it again and still have the same issue. Kinda annoying now.
You could also try a factory reset of the ATV but I have no idea if it would help. Could also contact support since staff aren’t very engaged here.
I went through an extensive back and forth with them on this bug. They have no idea what’s wrong and they don’t really care. That’s the feeling I got.
Mine is still the same - super annoying. I’ve given up
Same here. I’ve given up too.
I just miraculously got sound on the video for the last activity. I don’t know if this is a solution but unrelated to this (had a very low sound on Max app) I changed the Audio Format to “ON” and changed settings to Dolby Digital 5.1. I have no idea if this did the trick but it might be worth trying.
