I’ve just set my bike up on my son’s trainer as mine has broken. Only issue is I can’t calibrate the power output so reading and speed is ridiculously low. Followed the YouTube tutorials but no ‘wrench” appears and the unpair option doesn’t come up either.
Any help greatly appreciated.
Which trainer is it? Calibration should generally be done in the manufacturer’s app, not in Zwift.
Thanks Paul
Tacx
Pretty sure I never did that with the old one as that would be well beyond my capabilities!!!
It depends on which Tacx trainer it is. If it’s something like a Neo 2T, there is no calibration possible. If it’s a Flux or Flow Smart or something like that, you can use the Tacx app to calibrate it.
Thanks again Paul
It’s a Tacx Vortex
Turn off Zwift, run the Tacx app, calibrate it there. Calibration is saved to the trainer and does not need to be repeated in Zwift.
Thanks Paul
Will have to try that in the morning.
Really appreciate your help.
Hi @Alan_Lines, welcome back to the forums! This is Monica from the Zwift Team. I understand how important it is for you to resolve the calibration issue with your trainer.
After reviewing your account, I can see that your trainer is a Tacx Vortex. According to this helpful article, this trainer needs to be calibrated using the manufacturer’s app, as @Paul_Southworth mentioned.
Additionally, after calibration, I recommend updating the game version by following the steps outlined here.
If the issue persists, please contact us at support@zwift.com.
Garmin also has a support document for calibrating the Vortex
Since you said power readings appear to be low, that can be caused by tire slippage. A slipping tire on a wheel-on trainer can be caused by insufficient roller tension, a dirty roller, using an incorrect type of tire, or using a tire that is very old so the rubber is no longer grippy enough.
When I set up my wahoo I had to tell it what size wheel and tire I was using. Is it possible that you don’t have the same size wheel that your son has?
