I think these two buttons are layered wrong:
When trying to adjust the MTB steering sensitivity, using the slider control in the lower left side of the screen, if you have an upcoming event (29min or less to go), when you click on the Sensitivity Slider, it actually activates Join Event! Then you are whisked to the event start line… and have to close, restart Quatch Quest, and re-ride to the MTB trail.
The JoinEvent button is not actually shown when this occurs; just the Adjust Sens. button. This happened to me THREE times - very frustrating…
The following topic may also be related: Turn bug when going from MB to Event - #2 by Mike_Hanney
Also: The sensitivity slider works backwards, IMHO: It’s got slide LEFT as MORE sensitive, and slide RIGHT as less sensitive. That’s backwards to normal left to right 0-is-left, and MAX-is-right…
