Mt. Everest
Hi, the challenge Mt. Everest lost some meters, how can I get my meters back?
If I look at the challenge, the bike is near the top, but the meters are down at 9046/50000 and I am sure that I was much further than 9046m.
Greets Marc
The only way to recover lost progress is to contact support.
If you have the game installed on two devices and you leave one logged in and running while you switch to the other one, that’s a common way to lose progress. I don’t know if you did that, but I think support can tell you if that’s what is going on.
I’m not sure you actually lost any climbing meters.
The Everest Challenge consists, effectively, of two parts:
Part 1 involves climbing 8,850 meters (the height of Mt. Everest). When you climb this many meters, you are awarded the Trek Emonda bike frame. Additionally, at this point the in-game graphic will show your bike at the ‘top’ of Mt. Everest.
Part 2 involves climbing another 41,150 meters (making 50,000 total meters). When you reach 50,000 meters you will be awarded the Zwift Concept Z1 bike (also known as the Tron bike).
As you have noted that your graphic is showing 9,046/50,000 meters, my thought is that you recently completed Part 1 of the challenge. (Prior to this the graphic would have showed XXXX/8,850 meters climbed.) So now the graphic has changed to show how many meters of the 50,000 for Part 2 you have climbed. And because you are just past the 8,850 meters, your bike appears near the top of the mountain. Going forward, the graphic will show your bike continuing on into space, until you reach the 50,000 meters.
You should check your Garage to see if the Trek Emonda frame is there.
You can find more information about the Everest Challenge here:
