Hi. I’m after a cheap HRM for use in Zwift. Will the Mi Band 2 work in Zwift if it’s paired with my iPhone, and I use the Zwift mobile link app?
Thanks.
Thanks.
Should work, however, Zwift only tests polar, garmin, and wahoo hr straps.
“Zwift connects to your BLE enabled devices through the Zwift Mobile Link companion app on your phone. Make sure that your phone is on the same Wifi network as your computer.”
I found the Wahoo tickr to be the most optimal. You can get one of those around $40-50.
HI Ben Cook,
Did you figure out if it works? Was planning on doing the same! ![]()
Thanks a lot
No, I bought a Mio Link instead. Sorry.
Okey thanks a lot ![]()
