I have connected my Wattbike (with Model B) on latest firmware and I have successfully connected the bike via a Garmin Ant+.
But when I launch the race I cannot get the cyclist to move at all. Has anybody managed to get their Wattbike to work with Zwift? If so can you let me know how you have set it up?
Yes I did that I got the icons to go blue. Can you confirm what trainer I should select for the Wattbike and also which option is best to select e.g. ‘Speed Sensor + Classic Trainer’?
Wattbike should come up as a listed power source. If Wattbike has a built in cadence sensor, you’ll see it also listed as a cadence sensor. No need to select “Speed sensor + Classic” since the Wattbike has real power.
Just to let you know I got it working. I firstly removed the Garmin program re installed Zwift. Then re installed Zwift. The second thing I did which I had not done before was launch a profile on the Wattbike itself. As soon as I did this it worked as expected.
