My Surface Pro 7 keeps crashing in Zwift and the Zwift peeps tell me my on board GPU isn’t good enough.
So with the prices of Mac mini’s in free fall, what about putting the 1660Ti in an eGPU box and running it on a Mac Mini? Will this get me the ultra settings? Or at best, not crash all the time?
They’re talking bollocks. Assuming you have a 10th gen CPU and the issue is Zwift freezing, here’s a bug with the game on your iGPU that can be worked around with the use of an older Intel driver.
This would work, but I’m not sure why on earth you’d want to do it versus just putting the 1660 Ti in a PC for massively less money. Or getting an M1 version which gets High (albeit with broken rider shadows) without a separate GPU.
You don’t need a 1660 Ti to get Ultra profile, not even close. They’re staggeringly expensive at present.
I’m using an old (2012) mini with an eGPU. It takes a bit of hacking to get that setup to work at all. Then I had to edit the basic profile b/c Zwift doesn’t seem to know what to do with a radeon rx 5500 xt. In the end the rather ancient cpu seems to be the limiting factor.
If you don’t have the gear already, it would be a pretty expensive and labor intensive solution. In my case, I had everything put together before I ever tried Zwift.
