No idea whats happening but seem to have lost 40w in average when racing…normally 270/80 would feel hard but ok…240w is flat out now and HR is through the roof. Has there been an update of some sort?
Using kickr snap and i use to he able to check spin down reaults. Now it just says “done”.
Any help would he great.
How old is the tire on the bike ?
pretty new…loads of life left.
Normal easy make the break in “A” races then get hammered in the sprint…im now out the back door after 5 mins racing.
You are doing the spindown in the Wahoo app? Definitely prefer that over calibrating in Zwift.
The standard advice for wheel-on trainers is use a trainer tire, tension the roller according to the trainer manual, inflate the tire according to the trainer manual, and keep tire pressure perfectly consistent between spindowns. Use a digital tire pressure gauge.
Hi Paul
Yes…spin down in wahoo app. It use to give readings. But now just says “done”, no readings(so unable to tell if in the 10 - 15 sec zone).
I just loosend the tension roller on the wheel and that seemed better.
Sounds like something to discuss with Wahoo support.
