Will they ever get fixed?
Seems unlikely.
We sure itâs not just substandard asphalt and due to the summer heat is becoming more gummy? ![]()
Itâs more immersive (Sorry!)
maybe âsubmersibleâ?
As someone posted elsewhere, this âphenomenonâ seems to be most prevalent at intersections. Clearly there is some work needed for intersections all over the Zwift platform. Another issue I notice regularly is that the cobble feel (and I think sound) disappear in the Italian Villas section of Watopia if you are making the turn toward the volcano. Annoys me every time.
That bug happens in a number of places/cases. It was, for example, embarrassingly visible at the bottom of the radio tower descent in the vTdF broadcasts.
Yes; yet another intersection.
Itâs actually a bit worse than just intersections. The image above is indeed right after the intersection from the tower road to the main road (and they hit what feels like a curb right after that to go back to ânormalâ), but thereâs a bit of diving under the surface followed by hovering above in the descent prior to the intersection. The same thing happened with the men (including the dive and hover), it was masked by using a frontal view of the leaders through the spot shown above. Careful observation still shows the deep under-surface dive.
I have numerous areas on Zwift (running ATV) where the entire road surface is âfloatingâ over the surrounding ground.
Pretty sure all these are limitations and/or bugs with the road-building tools. In the Alpe du Zwift video Zwiftcast produced a couple of years ago itâs discussed that some of the artwork at the roadside is there to help mask the technical problems encountered with such tight turns and increasing elevation. âFloating roadâ is mentioned. Obviously hasnât changed.
How many years?
I rest my case.
