Lenovo Tab M10, will it work with Zwift?
It looks like my existing old Android tablet (Android 6.0) is now no longer supported by Zwift, it doesn’t seem to be getting any more updates. I’m thinking of buying a Lenovo M10 tablet, but just wanted to confirm that it will work with Zwift. It has a Snapdragon 450 which I think is the same for the Lenovo P10, another post says the P10 is Zwift compatible. TIA
Ive just brought one. the app works but I cant get my garmin sensors to pair with it via the ant+ been trying for the past 3 hours now
Ah, that’s useful information, thanks for the reply. So presumably you had to get an ant+ dongle, as I wouldn’t have thought the tablet would support ant+ out of the box?
ive been told I need to change my router to wpa2psk for it to accept it. still trying this out.
I’ve just purchased the P10 to use with Zwift and a classic trainer.
App works no problem, doesn’t connect to my Garmin Ant+ speed / cadence sensors but connects straight away to my Bluetooth speed sensor.
Looks like is if using the P10 you’ll need Bluetooth sensors for speed / cadence / heart rate monitors
So the M10 works fine? Trying to decide between M10 and P10
Yes, I’ve now got the M10 and it works fine. Using bluetooth to pair with Elite Direto trainer and a wahoo tickr heart rate monitor. I think these are going quite cheap in Argos if you are in the UK https://www.argos.co.uk/product/7660869 although they weren’t in stock at the time and I got one from Amazon.
Hi Rebecca,
Struggling with same problem on a p10. Garmin dual hrm fails to be found by zwift or wattbike app. Did you manage to resolve this in the end, nd if so, how?
Iain
Hi Iain, nope never found out how. It turned out the tablet isn’t compatible and has out of date software that couldn’t be upgraded to make it work.
hello, Lenovo Smart Tab M10 FHD Plus LTE Google Assistant (tb-x606x) with mediatek processor has no build in support for ANT. Look there - www devicespecifications com/en/comparison/6d4119c180
You can connect to Zwift by Blutoooth - i am using it with Tacx Trainer.
Or get a ANT+ dongle separately - maybe this could work…
la ceinture hrm Garmin n’est pas compatible il faut la ceinture Garmin hrm bluetooth pour que ce la fonctionne
I use the Wahoo Tickr which is both Ant+ and Bluetooth. It works with the tablet but is sometimes a bit difficult to pair.
Download the app called ANTtester and it will let you know what services you will need to download to enable ANT+ on your Android Device or if it’s ANT+ capable…I have a Lenovo Tab P11 and it never picked up the ANT+ Signal that my Kinetic Trainer broadcasted, but my Note10+ did…after some research there are Free Services that you need to download in order to get it enabled…after I did that it worked.
I just purchased the Lenovo tab 11plus. Which things exactly do you have to download to make the ANT+ work ?
Roeland sorry for the delay, I downloaded ANT+ Plugin Manager and ANT Test
Guys thank you, I solved my problem thanks to this topic
