Kit ZWIFT COG with Elite direto XR
Hello,
Is ther a document or clear instructio for what to do to connect the Commands of Zwift COG to get the virtual gear changing ?
Thanks for your reply
Hi
Best guess - I don’t have an Elite trainer.
Make sure you have the latest firmware on your trainer.
In the pairing screen pair your trainer over Bluetooth (or Wi-Fi), ANT+ is not supported for virtual shifting. Make sure to pair both power and resistance.
Pair the Zwift Click as Controllers.
now, theoretically, you should be able to use virtual shifting.
Yep. Spot on.
Hello,
I tested without ANT+, and paired Direto XR over Bluetooth (option through phone), then paired the Zwift Click as controllers.
When I validate to start the game is opens correctly with everything on screen, but nothing runs when pedalling.
No power from Trainer ???
Is there any action I missed ?
Best rgards
Gilles
Hello @Gilles_LE_GOUEDEC , welcome to Zwift Forums! I took a look at your recent logs and it looks like everything is updated properly and paired correctly. If you are pedaling, but seeing 0 watts (or “–” where your watts should be), you may want to double check that your trainer is working properly outside of Zwift. If you’re seeing power output in the first party My E-Training app, but not in Zwift, please feel free to open up a support ticket with us!
Hello,
I fixer the problem which was due tu bluetooth issue on my computer.
Using another computer everything is ok.
Thal you for your message.
Regards
Gilles
