Will the Zwift axle adapter work for the Kickr V2?
I believe the V2 only allows a QR skewer to pass through the drive body…so I’m wondering if this adapter kit will work for V2?
Hi @Andrew_Brogdon, welcome to Zwift forums. This is Haziel from Zwift support.
I wanted to let you know that the current Zwift axle adapter kits are specifically designed for trainers with swappable end caps. And the Kickr V2 doesn’t fit this design, so the Zwift adapter kit won’t be compatible with it.
I found a link that offers some information about the Thru axle adapter, and I strongly encourage you to reach out to Wahoo directly for the best advice specific to your setup. Their team is very helpful and can assist you further.
If you have any other questions or need more support, please don’t hesitate to reach out at support@zwift.com. We’re here to help you get everything sorted!
