Anyone know why the cassette wobbles on my Kickr when rotating?
It happens on all cassettes, even brand knew cassettes, and when installed on my wheels are fine.
Everything torqued to spec, installed and indexed correctly.
Kickr Cassette Woble
Huwelfedus_Maximus
(Huwelfedus)
#1
Gerrie_Delport_TeamZ
(Gerrie)
#2
Did you add the spacer. Is it a 10 speed cassette on a 11 speed Kickr freehub body?
Greenfritos
(G reenfritos(SVCG))
#4
Is your freewheel body worn? If at some point the cassette came loose and you used your Kickr that could wear the body down, so any cassette would wobble. I’ve seen this on wheels before, and required a new body to be installed. Check for wear on the body, digs in the ridges. Using a body/cassette combo that wobbles for any time will worsen this, so I wouldn’t use your Kickr until it’s solved.
Huwelfedus_Maximus
(Huwelfedus)
#5
So finally managed to find a new freehub for my Kickr and wobble gone!!
