Is it possible to Just Ride, without having to specify a predetermined route or select a workout?
There’s a button saying Just Ride on the start screen, but it requires you to select something from the Workout menu…
For Just Ride all you need to choose is the World and the route, no selection within Workouts is needed.
You have a “route” whenever you don’t use a “workout”. You can change the route before you start. Once you start you can then vary the route at any intersection. As you get used to where the routes start, there are limited “spawning” points in Zwift, you can get to different places you want to go in the world easier and faster. Remember you can always start a route and then turn around to get some where that was behind you when you started.
Thanks everyone. i understand now
