When is the Jet Black Whisper drive gong to be on the supported list of trainers?
Other than selecting the “non Listed trainer” as a setting, what other trainer is the closest compatibility to the Whisper Drive?
Thanks.
Thanks.
We have no plans to support the Whisperdrive at this time. It’s a direct drive trainer without a specialty sensor we can adapt, so you’ll always need a power meter.
There is also no “close” trainer when it comes to zPower, so you’ll need to select Not Listed to ride in Zwift.
That’s a shame. It comes with a Jet Black speed and cadence sensor.
http://www.bikebarn.co.nz/jetblack-speed-sensor-whisperdrive.html
What type of power meter is recommended? They seem to cost as much if not more than the trainer itself.
If I have to use other trainer for jet black whisper drive, is there any way to check if the speed/power reading is remotely right?
